Recommend Good Wideband setup
Old 12-29-2016, 09:35 PM
07Softail's Avatar
Default Recommend Good Wideband setup
I need to get a wideband for tuning my Boosted build what is a good setup that you would recommend.
RT
Old 12-29-2016, 09:49 PM
FFDP's Avatar
Budget?
Tuning software you are running?
The newest AEM wideband is pretty nice, works with HP Tuner very well. Has it's own ODB2 cable now too for can-bus output.
https://www.montmotorsports.com/aem-...troller-gauge/
Also for the most part about all of the $150-250 widebands on the market all use the same exact Bosch 4.9LSU sensor so one can't really say that one is going to worlds better than the other. It comes down to what the gauge looks like type of thing more often.
Old 12-29-2016, 11:15 PM
2002_Z28_Six_Speed's Avatar
Not Innovate.
Old 12-30-2016, 03:15 AM
About20ninj45's Avatar
Plx wideband and 02
Old 12-30-2016, 07:40 AM
madmann26's Avatar
Originally Posted by FFDP
Budget?
That's neat.
I use the older AEM WB - digital one. It works well with the MPVI Pro interface, no issues, not buggy.
I also have an Innovate LM2. It's a bit more special (buggy).
My vote is for the AEM.
Old 12-30-2016, 08:15 AM
I have a gauge for that
Atomic's Avatar
This one with the NTK sensor, Home » Shop » Wideband O2 » O2 Controller » AFR500v2 - Air Fuel Ratio Monitor Kit - Wideband O2 System
Old 12-30-2016, 12:29 PM
07Softail's Avatar
Budget is $200 or less Im looking at the PLX Gen-4 right now, and I have EFI Live.
RT
Old 12-30-2016, 12:41 PM
ezdaar's Avatar
Simple, aem uego.
Works perfect.
Old 12-30-2016, 06:09 PM
Ken in AZ's Avatar
I like my PLX - has a voltage output that interfaced with the egr input on my pcm - a little patience and searching showed that you can set up math parameters for it to read AFR in HPTuners.
It also uses a multi gauge - I'll let you know how that works when I install the oil temp sensor I just got. Pretty nifty how you can multiplex different gauges into one multi gauge.
Old 12-30-2016, 06:54 PM
Atomic's Avatar
I would expand your budget for a wideband. Having a good one is very important and not something you want to cheap out on. If you buy a used one, get a new replacement sensor first thing. They are consumables and wear out.
