Random misfire at high loads
Registered User
Im getting random knock, especially at higher loads and feel its a sensor or maybe ground. My question is what order should I follow in diagnosing/ replacing sensors?
Ive replaced plugs/wires and replaced MAF sensor with known good unit. I have a 5.3 that I can trade sensors with.
Registered User
What it cant do both??*? Its missing badly,all on bank 2. Its also showing knock. Ive now replaced plugs, wires, coil pack on b2, 02 sensors, maf, map with no change. Could a faulty crank or cam sensor be causing this issue?
Registered User
They looked really close to the plugs on bank 1. I changed out crank sensor with no luck. Last sensor I can change is cam sensor. Im going to try and pop it out without pulling intake but if not i will bite the bullet.
Im getting a little bit of misfire on cylinder 3 now and its def not drivabl . Cant even do a crank relearn as it wont rev past 3k.
Shtbox
03-28-2016 04:31 PM
