TCM is Locking Converter!?!
Old 02-06-2011, 11:51 PM
9 Second Club
Rhino79's Avatar
Default TCM is Locking Converter!?!
I have raised the apply and release tables for the converter to keep it from locking at wot, but no matter what I do, it locks it at about 98 mph in third.......I do not see in my calibration where I could disable the slip test, I wonder if I could select "no" for input speed sensor and would that bypass any slip tests??
Old 02-07-2011, 06:22 PM
9 Second Club
Rhino79's Avatar
Does anyone with HPT know if there is a table in the 09's for trans slip test?? I do not have one in my os and I have posted on efilive with no hits. I found an 08 os did have the test min and max speeds in it. But I believe a full reflash would cause some stabilitrak problem as I tried this once before. Its not a super big deal at the moment, but with gears I will be in 3rd much sooner.
Old 02-07-2011, 06:24 PM
dlt76028's Avatar
did you change the 3rd gear 100% throttle shift table?
Old 02-07-2011, 06:28 PM
Where's the Beef?
viciousknid's Avatar
+1
the other table just adjusts the pressure that is applied. not when it applies.
Old 02-07-2011, 06:54 PM
9 Second Club
Rhino79's Avatar
The 3rd and 4th apply tables are set to 318 mph from about 50%- 100% throttle
Old 02-07-2011, 07:01 PM
dlt76028's Avatar
Not the apply tables, the actual upshift table.
Old 02-07-2011, 07:02 PM
Where's the Beef?
I don't know about HPT but in EFI Live the max you can put is 256mph. try that perhaps?
Old 02-07-2011, 07:09 PM
Resident Retard
BlackGMC's Avatar
Post #6
http://forum.efilive.com/showthread....ighlight=d7013
Old 02-07-2011, 07:17 PM
Resident Retard
BlackGMC's Avatar
I looks like your tune is missing D7013-5
Old 02-07-2011, 07:21 PM
9 Second Club
Rhino79's Avatar
D7013 is not in my os, I found that last night tho. Its the same thing mine is doing.
Quick Reply: TCM is Locking Converter!?!
