No start after mail order tune
Old 08-22-2016, 05:38 PM
Brian Mock's Avatar
Default No start after mail order tune
Got my black bear tune in today, swapped the pcm/tcm over, it started, stubbled and stalled, no security light ever came on but I tried the the relearn procedure, no it just cranks no start, I don't hear the fuel pump. I swapped my stock pcm over it starts right up... Any ideas?
Old 08-22-2016, 05:42 PM
FFDP's Avatar
If doing a security relearn didn't help, then I blame the tune you got from them.
Something may not be setup right.
Old 08-22-2016, 05:47 PM
Brian Mock's Avatar
Does the security relearn need to be performed even if the light isn't on? I mean it says in the included says that the truck may run and then stall out but everything I look at online says that the light will be on. I am wondering if you still need to perform it without the light on but I tried x4 times and still nothing I'm wondering if I did it wrong or if something is wrong with the computer... I'm going nuts
Old 08-23-2016, 07:41 AM
darkirish63's Avatar
Before I had Alvin @ PCM of NC tune my truck, I had a couple mail order tunes from Justin - never had an issue & YES, you have to do the entire re-learn sequence even if there is no security light present. Its time consuming, yes, but your truck won't run unless its done. When I had my stroker dropped in I had the adjustments made by Justin via mail order and on the first attempt I got nothing because I didn't correctly perform the re-learn.
Good luck...
Old 08-23-2016, 07:53 AM
Brian Mock's Avatar
I understand and I'm going to try it this morning over again however I put there pcm in the truck this morning an it started right up again but was spitting and spuddering and while running I checked for codes...
Engine misfire detected a long with every ignition coil control circuit fault...
P0300, p0354, p0355, p0356 ect ect... Any ideas?
Old 08-23-2016, 11:45 AM
It threw the codes after you did the re-learn? Very odd...
Old 08-24-2016, 06:08 AM
Brian Mock's Avatar
So just a update, after talking to Justin and Jarrad at blackbear, they are sending me another computer due to possible fault with this one, maybe shipping damage.
Old 08-24-2016, 10:30 AM
FFDP's Avatar
Most computers are pretty much shock proof and weather proof, think of what people do with these vehicles.
I'd guess at a tuning error on their end.
Old 09-05-2016, 01:40 PM
S14serge's Avatar
What were the specs of your tune if you don't mind me asking? Did the problem ever get resolved? Looking into black bear tunes myself.
Alco
06-27-2016 08:18 PM
09CamdSilvy
04-17-2016 09:17 PM
Alvin@PCMofNC
03-25-2016 11:16 AM
Go5.3tt06
03-21-2016 05:52 AM
nitrousaddict
02-23-2016 05:18 PM
Quick Reply: No start after mail order tune
