Need help on Clutch safety switch "UPGRADE"
I hooked the factory switch to a circuit tester that ran all circuits at once and purple and brown never closed a circuit together. They may work together down stream or at the bcm, but not inside the switch.
I wired the micro switches up so they work in the same manor as the factory switch, so if that circuit connects later down stream, then it should still be functioning as normal.
I ended up solving the issue, and like most people, I never updated the post with what the solution was.
I installed 3 micro switches, and wired them the same as the three legs of the factory clutch safety switch. The issue I was having that was making me scratch my head, was that it did not allow the truck to crank, and it turned out to be the green connector that plugs in to the junction box at the bottom of the firewall near the floor. It was loose, and not clicked in. I plugged that in, and POOF all worked awesome. I drove the truck all summer, and not one issue with it!
Dusty05
07-12-2016 04:19 PM
Tehcaptainjack
11
06-02-2016 06:47 PM
nathanstowing
06-01-2016 06:04 PM
