LS swap not making anymore power past 4700 RPM
#31
Formerly ScreamingL
#33
afr was 12.8 i believe and timing around 27-28
heres a log for you im not sure if it has everything you need on it but its a start.
The high rpm action starts a little before frame 160
everything seems to be in line.. im seriously debating on swapping in a new cam while i have the cover off
#34
exactly what i thought, i was hoping to find the dots off or something. But no im starting to think its in the cam grind itself, but i dont have a degree wheel to confirm
#35
Formerly ScreamingL
ive heard of cams being just way off from advertised, Also for that size of motor the power is down anyways with a cam that size
your this far into it, yank cam out and go with another cam
#36
