L31 Vortec tuning
L31 Vortec tuning
Hi guys. So I have a 97 K2500 suburban with the 5.7 L31. I have had a JET hand held tuner tune on it for a couple years. I will be swapping over to a 411 pcm in the next couple weeks (Mild LQ9 will be going in in the early summer). I do have access to HP tuners and I will be tuning the 411 PCM and segment swap, I have that down pretty good. Question is, has anyone pulled a JET tune off of their black box pcm? (97,98,99) and compared to a stock 97-99 tune? I like some of the things that tune did to the truck and of course dont like some of the things it did. I would like to compare both tuned and stock tunes to see what that programmer actually changes. I believe the 97-99 L31 had the same tune but only the 98,99 computers HP tuners can read. So If anyone in the Boston area has a Stock 98,99 L31 truck and wants this JET programmer you can have it, I just would like to pull the tuned and stock file off your truck.
There is a Jet tuner program that was originally Tuner Cat program that is fairly versatile for tuning even LS motors. Not sure HP can read anything that is not a 411, at least from what they told me years ago-even thought the Jet/Tuner cat can.
My experience with handheld from Hypertech on my 97 Vortec was their tune made it ping more and actually ran slower.
A jet hand held tuner is like a Hypertch, not the same as the Tunercat OBD2/Jet Dynamic Spectrum tuner.
OP I've read plenty of 96-99 Black box PCMs with Hypertech tunes installed and you would laugh at how little they change vs their cost. I would guess the Jet hand held is not much different. HP tuners only supports the 98-99 black box PCMs so you would have to have the TC OBD2 or Jet DST to even see what was changed on a 96-97. I have TC OBD2.
I understand that HP only supports the 98+ black box. That is why I was looking for some one with a 98+. That way I could load this JET program on their computer and be able to pull it with HP. I understand that the JET thing blows, however there are a few parameters that I like about it and I want to know specifically what those are. The only way to do that is to pull the tune.
Are you sure a JET Tuner for a 97 will even load on a 98? Even though 96-97 black box PCMs look similar to 98-99 externally they are different internally and the 96-97 PCMs have 5 connectors instead of 4. The calibrations are quite different too. And if you can't see what it is changing how do you know what the parameters are that you like? I understand what you are wanting to do but it is not the way to tune.
The JET programmer works on all the L31 motors without a 411 pcm. so from 96-2000. I was curious about what specifically this tuner changes on the ecu. I know I will be able to tune it with the 411 to the way I like it, I was just trying to gather some more information.
Weird...I used the Hypertech spark map on my 1997 L31 Express Van I pulled from a 1998 C1500 that was Hypertech tuned. Ran 91 octane or better and never saw a detonation issue. Never really saw any knock retard either. I smoothed out the area they left untouched between the stock lower load timing table and the WOT timing they added. I did enable PE fuel earlier and bypassed the delay. Set the stoich fuel value to 14.1:1 to match the E10 gas and kept my PE AFR around 12.00 at peak torque and tapered off to 12.6 at peak hp and above. Dropped about 4 tenths off my 1/8 mile time. Factory LT4 cam and 1.6 rockers ran fine on that tune as well. Between the tuning/cam/rockers and 4.3 S10 converter I knocked a full second off the 1/8 mile times running stock manifolds.
Really not worried about what you think!!
This is the Hypertech based map I have been running for years. Only small tweaks and some smoothing from what they tuned these engines with. With the stock cam they run 28° total timing. With any cam change at all, I see best results around 30°.
Before/STOCK
https://www.youtube.com/watch?v=WydwLghk_yw
After
https://www.youtube.com/watch?v=7SgptElOCpY
Before/STOCK
After
