knock retard with e85?
Tuner says its probably just false knock. Its a 5.3 with 10.5:1 compression, 13.5lbs of boost and 16 degrees of timing, e85. I believe the target AFR is 11.9 on the gas scale. Would it be wise to desensitize my knock sensors while on the E?
So I went out and did some data logging tonight. I found the points where it was knocking and pulled some timing and it was still showing knock retard in that area. I ended up pulling a total of 4 degrees and I still saw about 2 degrees of KR still. Its not consistent and it also doesn't pull the same amount of KR every time, so I am going to assume its false knock. The only somewhat consistent thing is when it happens, around 5300rpm. A issue I did notice though it that my AFR's seemed to be all over the place and not consistent at all. I seen it as low as 11.0 up to almost 13.0 at some points on the log.
