Ignition button
Old 02-06-2017, 05:41 PM
cromedome's Avatar
Default Ignition button
Trying to wire the truck up so i can push a button to start the truck kinda like what you see on nascar. Is there a thread for this? Would be a security thing for me
Old 02-09-2017, 12:53 PM
MikeGyver's Avatar
It is not practical to try to convert a foot-operated starter to push-button or key-turn operation. However, you can easily replace your starter with a solenoid type.
In your case you will need to use a 6 volt starter from a 49-54 passenger car. A later 12 volt starter will not mesh properly with your "6 volt" flywheel because the gear tooth pitch is different. The 6 volt starter will usually survive quite well on 12 volts. If you decide to use a 12 volt starter instead, then you will also need to replace the flywheel with one from a 55-62 235 car or truck.
Old 02-09-2017, 04:54 PM
cromedome's Avatar
Um...ok...i had a ranger that all i had to do was hook some wires from something to a switch and it worked fine....sorry about the caps lock
Old 02-09-2017, 07:03 PM
MikeGyver's Avatar
I have wiring diagrams for year 2000 GMC/Chevy 1500, 2500, and 3500 if that would help. Since you won't tell us what year or even brand of truck that you want to put the button on, I decided that you have a '52 Chevy pickup with an inline six.
wretched73 (02-10-2017)
Old 02-10-2017, 08:58 AM
cromedome's Avatar
93 chevy 1500
Old 02-10-2017, 09:18 AM
MikeGyver's Avatar
I found the diagram instantly with a Google search.
http://repairguide.autozone.com/znet...3f80231a24.gif
It seems that it was the purple wire since the 1950s. Cut the purple wire (A) at the column connector. Run a wire from one side of your button to the wire that you removed from the connector. Piggyback the other wire from your button to the red wire (D).
Now the key won't crank the engine, but the button will. Done.
cromedome (02-15-2017)
Old 02-10-2017, 09:25 AM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
^ I like this guy
hahaha
