How to pick out a bad tune/tuning?
I've been around for a while I've been using Nelson! He has done great things for my truck For when it was NA. time has went on games have changed - I'm now forced induction- it's past the point of mail order tune so I picked up EFI live and started learning.
Reading one thread after another I figured I'd ask the question what is the most common thing to pick out a good tune or what tuners use to cut corners to make a quick buck?
I've hooked up to a couple friends trucks with 5.3 and 6.0 and some only have minor spark adjustment - maybe MAF adjusted - shift points
Nothing concerning e10 fuel adjustments in afr- because around here it seems like every other gas station has e10
Just curious of the input this might have
I don't even bother changing the stoich for E10 fuel because it varies from 3-8% E content on a regular basis. 14.68 works just fine for a stoich with ~E10 fuel and no real alcohol sensor.
Depending on what is done to the vehicle and what the person is trying to achive it can be somewhat easy to see if a tune is bad or very far off. Watching the data logs/scans can give away big problems if you have an idea of what you are looking for.
It's pretty common to find tunes that just rape the PE table instead of tuning the VE/MAF correctly, or they disable all fuel trims because they can't tune it correctly. Or another big thing to find is someone that just disables the VE altogether and runs only MAF because they don't wish to take the time to tune both.
Couple of the guys of had small cams -long tube headers- cold air induction - couple stockers cams - with just cold air induction with long tubes
Nothing forced induction I've hooked up to.
I'm in the process of tuning my buddies 6.0 with the TSP 228 cam- dialing in the VE is interesting and makes sense to do! It makes me want to do it to my stock 05 crewcab
I cannot believe some actually shut VE completely off. ANd modifying PE only
Anyway, it's very rewarding to figure out how to successfully tune your own rig and you will discover that these PCMs are actually quite forgiving and people can cut a lot of corners to obtain a strong feeling and "safe" tune without actually doing it right. I looked at a lot of tunes for reference while getting HPTuners figured out and there are some sketchy looking files out there from people who supposedly know what they're doing and charge people a lot of money for their services.
You could force it to run 100% MAF but there is a small catch, the VE or VVE is still used for transient fueling no matter what "mode" you have it set in.
I see it all the time where a boosted vehicle has the dynamic airflow set to sub 500rpm disable and they only tune the MAF. The VE or VVE will still be all stock still because they don't take the time to tune it. Some don't even run 2 BAR map sensors either because they think just running the MAF is the "best" way.
This couldn't be more true!
