Help!!! No start problem for days now
Old 05-05-2016, 12:27 AM
  #21
TXsilverado's Avatar
The vat sydtem will let a truck start for about 3 seconds before cutting spark. Seriously doubt its vats
Old 05-05-2016, 12:30 AM
  #22
Replace both your crank and cam sensor. Im confident it will fix your issue, and if it doesnt, they are both great maintenance items at 285,000. Theyre due for a failure soon if they arent causing your current issues.
I wouldnt expect a fuse since it started as an intermittent issue.
Old 05-05-2016, 12:36 AM
  #23
BlueTexan24's Avatar
Yes I checked the fuses under the dash as well. And when I turn the key on it alternates every 5 seconds between the red battery and low fuel. The security light flashes when the door is open but it's always does that.
Old 05-05-2016, 12:41 AM
  #24
I'm starting to lean more towards the crank sensor. Especially after going through the scanner and finding this on the security data
Old 05-05-2016, 12:54 AM
  #25
Wolftrk99's Avatar
Wouldnt be first time a bad crank sensor has caused an issue!!
Old 05-05-2016, 12:47 PM
  #26
So I changed the cam position sensor and it's the same
Old 05-05-2016, 12:50 PM
  #27
*crank position sensor my bad
Old 05-05-2016, 03:19 PM
  #28
you mentioned there was a voltage drop at key-on. how bad is it?
Old 05-05-2016, 04:41 PM
  #29
3-4 volts if I remember right.
Here's another theory and I'm gonna get **** for this but currently i just got it started and running and everything seemed fine and I got home turned it off and same problem and I checked the ignition and fuel pump relays and they were hot so I took them out and put an ice pack on them for a few mins and it started right up......I have a walbro 450 in the tank and running it through the stock harness cause my Hotwire kit I had on it burned a pin up from a bad ground issue. Think it could be causing the relays to get too hot and not work right? Cause they were hot enough to burn your finger
Old 05-05-2016, 09:22 PM
  #30
Wolftrk99's Avatar
I think you need to check the wiring if relays are getting hot something is shorted, surprised you arent blowing fuses if relats are that hot....
Quick Reply: Help!!! No start problem for days now
