Help! 07 Tahoe acting weird!!!
The truck is tuned through HP tuners... Here's the problem, for some reason after putting gas in the truck, it will act like it was never tuned? The A/F will stay at 14.7 no matter what kind of boost it sees? This will go on for five or ten minutes of driving around and then it goes back to normal.... Except for the fuel tables will be off and the HP/TQ will be down?! It does this everytime I put fuel in it!
So just to be clear... After tuning, the truck is strong and running good, until I put fuel in it, then it acts like it was never tuned, for about five or ten minutes, then it goes back to normal, but loses power?!!
Any ideas?
Any ideas?
Formerly ScreamingL
has to do with you cracking the seal for the evap system, check to make sure you dont have any pinched lines as this makes alot of sense
as more you drive more vacuum is created with line being pinched. once cap is opened it allows the lines to become unpinched. if this is correct then youll need a new tune once you fix your issues
