Help! 07 Tahoe acting weird!!!
#24
Custm2500's Rude Friend
The 02 sensors themselves don't change it.
It uses the readings from the 02 sensor to adjust for the ethanol content. AKA a Virtual Flex-Fuel Sensor.
I believe it looks for a change in the fuel level before making adjustments.
This seems to be similar to what you are describing.
This document describes it better. Scroll down to the interference method about 1/2 way down and read about it. http://www.siucautomotive.com/presen...s/flexfuel.pdf
#25
With Flex fuel settings enabled,
#29
E-85 Refueling Events - Hybrids, XFE, & Active Fuel Management - GM-Trucks.com
