Header install
From reading your SIG for the vehicle, you will want to delete all REAR o2 sensor related codes. You also want to keep the rear o2 sensors plugged in but they don't have to stay in the exhaust. If you leave them unplugged the truck will go into a cat test mode that you can't shut off. If you had a wideband you'd see the huge swings in AFR as it does this on and off all the time while you drive. Keep the sensors plugged in allow for only 1 test after the truck hits closed loop and then it won't do it again on that drive cycle. I've been down this road already.
Or you can just do the codes part of it and leave it. It won't hurt anything but it just won't be as good as it can be.
zblee
63
06-10-2023 01:25 PM
zblee
08-03-2015 03:45 AM
