GM Electronic Throttle Control
Would anyone know why my 2000 truck dbw system open up a newer 6 pin throttle body backwords? When i turn ing on goes to wot. As i press the pedal it closes. I have swapped every wire trying to get this to work. It only works in reverse???
I tried swapping those pins and the throttle body blade jumps then stays closed. it will not follow pedal input. I can only get it to work with pedal if I swap the TAC wires but it functions backwards. (WOT to idle)). Any other way the blade just jumps then stays closed and will not follow pedal input. I am using a throttle body out of an 08 hd pickup that had a 6.0 with l92 heads. 6 pin connector as shown above.
MA$TER_E
09-09-2015 03:14 PM
