Flashing battery light after multiple mods at once?
Old 05-29-2016, 11:16 AM
slonlow2000's Avatar
Default Flashing battery light after multiple mods at once?
Truck in question is a 99 2wd Sierra. I had my trans let loose so I had to pull it to rebuild. At that time I figured I would do a few mods at the same time to save on down time. Here's a list of what all was done.
Rebuilt trans (original was rebuilt)
Pcm tune by blackbear (original was sent in and sent back)
Speed engineering lt's
Deleted egr, rear o2's, and cats
Yesterday was the 1st start in over a month. The battery is a optima yellow top that's only a few months old and was pulled from the truck when I lost the trans and sat on my work bench. Volt meter is reading just above 14 and everything is working correctly. I drove it around for a hour yesterday. I've looked over all my wiring around the headers and nothing looks disturbed. Any ideas?
Old 05-29-2016, 04:01 PM
TOTM: January 2007
Last Call's Avatar
It might be the battery light if Blackbear upgraded the OS from a 99 to an 02. I would start there.
Old 05-29-2016, 06:53 PM
Yeah I've been reading people swapping to newer pcms are running into this. When I get to work Tuesday I'll pull the codes and see what code I'm getting and get ahold of blackbear.
Old 05-30-2016, 05:29 PM
Suburbazine's Avatar
You're not likely to get anything from OBD if you pull codes with a generic. You'd need a Tech II to see alternator errors (think it's P1637 or 38). But making them go away is nigh impossible- you can even set them to no error reported or disabled and the battery light still flashes and the code still sets (in Tech II).
Old 05-31-2016, 11:07 AM
TOTM: January 2007
Last Call's Avatar
I disabled mine with EFILive, I think it is in the system section under Alternator Terminal. Blackbear should be able to fix it if that's the issue.
Old 05-31-2016, 02:50 PM
Alright, it was predicting storms today so I didn't get to bring it in. I'll drive it in tomorrow. I'm going to go ahead and email blackbear though.
Old 07-01-2016, 08:11 AM
JDC
JDC's Avatar
Mine did that when i went from the 99 ECM to an 02 ECM I had to run a wire from the Altenator to the ECM.
Old 07-01-2016, 12:29 PM
Custm2500's Rude Friend
1FastBrick's Avatar
All you have to do is change the alternator terminal options in the platform section of the tune when switching from a 99-00 to an 02 OS
No need to rewire or turn lights off.
a 1999 OS has Terminal L only. Terminal F is OFF
a 2002 OS has Terminal L and Terminal F both turned ON.
Just turn Terminal F OFF in the 2002 OS under the GMT800 Platform when using on a 99-00 truck.
01ssreda4
46
06-30-2020 03:59 PM
t72ss402
05-30-2016 07:15 AM
camaro402
05-27-2016 01:38 PM
Mark Johnson
05-27-2016 09:11 AM
TURBHOE
05-25-2016 12:36 PM
Quick Reply: Flashing battery light after multiple mods at once?
