engine stays running when key is off and out - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 08-31-2012, 08:58 PM   #1
charcoal03silvy's Avatar
Default engine stays running when key is off and out
Long story short... Go to turn the truck off, and the engine stays running. Everything interior, lights, etc turn off like they should, but not the engine.
Pull fuel pump relay and battery neg. cable to kill it. connect battery and fans, pump, etc come on like the key is in the on position even though its off/out.
Starts up fine, drives fine, key turns fine and comes out fine, but engine won't shut off.
Please tell me all I need to do is pick up a new ignition switch from O'Reilly's and don't need to get the Cylinder rebuilt etc etc..
charcoal03silvy is offline   Reply With Quote
Old 08-31-2012, 09:35 PM   #2
2000chevysilverado's Avatar
Do you have efans, if so just went through the same thing ended up being the relay harness two wires pulled out the constant hot and ignition were touching it would stay running till all fuel was pressure was gone
2000chevysilverado is offline   Reply With Quote
Old 08-31-2012, 10:35 PM   #3
12 Second Club
Hemi2Slo's Avatar
I had the same problem with mine before I hooked my fans to my computer. Turned out to be the e fan harness letting power feed back to the ignition through the a/c wire. Disconnected that and problem solved. Hooked the fans up to the computer after that.
Hemi2Slo is offline   Reply With Quote
Old 09-01-2012, 01:40 PM   #4
Prob just bad ignition switch replace it and you should be good to go.
01WS6/tamu is offline   Reply With Quote
Old 09-02-2012, 07:42 PM   #5
It was the electric fan wiring! Thanks guys. Saved me a lot of time and cash!
Old 09-02-2012, 09:05 PM   #6
Good to hear
Thread Thread Starter Forum Replies Last Post
best traction street tire stealthperf General Truck Racing and Discussion 34 02-14-2016 11:35 AM
electrical issue out of the blue atxlt Tuning, Diagnostics, Electronics, and Wiring 1 07-20-2015 11:06 PM
hesitation at full throttle, normal at partial throttle bsgiffor GMT 800 & Older GM General Discussion 1 07-19-2015 11:14 AM
Need help - Stumble at first cold start, dealer can't find anything wrong Mossyoakglock GMT 900 Trucks General Discussion 0 07-17-2015 08:30 AM
HELP NEEDED OBS LQ9 swap going into reduced engine power mode GreyChevy Tuning, Diagnostics, Electronics, and Wiring 1 07-07-2015 08:57 PM
Tags
09, bad, cut, engine, ignition, key, keys, motor, relay, removed, running, shut, silverado, stays, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
