Help plz
Help plz
Im already frustrated as fkk with the damn truck my tuner told me it was leaning out at wot not enough fuel then my truck got to a point where it wouldmt advance past 5000 rpm or so itd b sputtering and choking at wot but normal driving is fine soni bought a walbro fuel pumo same issue happend they told me I used the wrong hose that I had to use my oem plastic hose so I put it and my truck openz up alot better but when I put the towhaul and fkoor it you still hear it sputtering and u see the rpms where they stay then like it hoes away and they start reving up then it sputters again my tuner said the fuel tables were maxed out im at a point of givingup anybody had this issue? Please of so chime in thanks
I'm already frustrated as fkk with the damn truck. My tuner told me it was leaning out at wot, not enough fuel. Then my truck got to a point where it wouldn't advance past 5000 rpm or so. It'd be sputtering and choking at wot, but normal driving is fine. So I bought a walbro fuel pump, same issue happened. They told me I used the wrong hose, that I had to use my oem plastic hose. So I put it and my truck openz up alot better, but when I put the tow/haul and floor it you still hear it sputtering and you see the rpms where they stay, then like it hoes away and they start reving up. Then it sputters again. My tuner said the fuel tables were maxed out. I'm at a point of giving up. Anybody had this issue? Please if so, chime in. Thanks
*WILDSTYLE 5.3*
48
06-04-2006 12:33 AM
*WILDSTYLE 5.3*
02-13-2006 09:32 AM
