any one solved the P069E code problem? - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 11-29-2011, 12:40 PM   #1
Question any one solved the P069E code problem?
the code appeared today in my uncels 09 tahoe 5.3 non e85 motor
the engine has a weard knocking sound and it starts after traying to start it for many times but it shuts off after 5-7 minutes
this happend after we drove throuh a water strem that was 2-3ft high
i lookede for the code arround here it was
" Fuel Pump Control Module Requested MIL Illumination "
any one solved this??
sand man is offline   Reply With Quote
Old 11-30-2011, 07:06 PM   #2
bumb bumb
Old 12-02-2011, 05:14 PM   #3
Gotta use a tech 2 scan the Fuel pump control module and find out what code it has and why it's detecting it. The code you mentioned is just a flag code sent to the PCM by the fuel pump control module to turn on the MIL and alert the driver to a problem
01WS6/tamu is offline   Reply With Quote
Old 12-03-2011, 09:57 PM   #4
ramairracer's Avatar
im a gm driveability tech and the p069e if fuel pump module request illumiation, i bleieve that year has a recall for the modules getting water in them or simply the module goes bad thats the only real problems i recall seeing
ramairracer is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Yet another P0300 Thread, Desperately Need Help Tydriver GM Engine & Exhaust Performance 45 10-23-2015 10:19 PM
Removing 4L80E and Transfer Case on 2001 2500HD 69z-28 GM Drivetrain & Suspension 17 09-21-2015 08:31 AM
new guy from ohio kmcn47 New Members 0 09-17-2015 02:12 AM
Knock Sensor Fix #2 Pimpinpete GM Engine & Exhaust Performance 3 09-08-2015 08:39 PM
Need some help with troublshooting of electronics and PCM muncie21 Tuning, Diagnostics, Electronics, and Wiring 2 09-07-2015 10:55 PM
Tags
chevrolet, chevy, code, control, engine, fuel, gm, illumination, mil, module, p069e, pump, requested, tahoe, trouble
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
