Any Michigan boosted ls tuners?
Registered User
Looking for a tuner with chassis dyno to bounce my build off of and make sure I'm building a reliable daily rig.
My truck is a 95 2dr Yukon Tahoe whatever you want to call it lol.
Weight: 4800lbs
14bolt 4.10 swap
4wd
4l80e swap in no stall speed yet. But would like be able to tow 5k
Nv241 t case
33" tire
5.3 gen 3
Callie compstar h beam rods
Lil john boosted flat top 5.3 pistons
Stock balanced crank
Mellings high volume oil pump
celvite rod n main bearings
Biggest a2a cooler I can fit
Solid bushing stock rockers
Unmilled 243 heads btr platinum dual springs new valves
Cam Specs are 212/218 .553/.553 113+2 stage 2 truck cam
Gen4 truck intake 92mm tb
Deka 80lb injectors
Single 340 fuel pump
3/8 fuel line
On an s366 66/73 .88a/r
I need help in deciding how to set up tuning to go with MAF or speed density and anything I'm missing or??
Weight: 4800lbs
14bolt 4.10 swap
4wd
Nv241 t case
33" tire
5.3 gen 3
Deka 80lb injectors
3/8 fuel line
BoostinJonnyukon (03-01-2017)
Registered User
Weight: 4800lbs
14bolt 4.10 swap
4wd
Nv241 t case
33" tire
5.3 gen 3
Deka 80lb injectors
3/8 fuel line
Weight: 4800lbs
14bolt 4.10 swap
4wd
Nv241 t case
33" tire
5.3 gen 3
Deka 80lb injectors
3/8 fuel line
