alternator wiring
Old 11-24-2013, 02:44 PM
TXsilverado's Avatar
Default alternator wiring
everything that i'm finding deals with Camaro and Vette alternators.
my plug is labeled P L I S. what wires do I need to run to get this thing working?
Old 11-25-2013, 01:36 AM
Custm2500's Rude Friend
1FastBrick's Avatar
What alternator are you using???
What wiring harness and operating system are you using???
Old 12-01-2013, 02:37 AM
1FastBrick's Avatar
Since the different systems use different plugs we would need to know what your using, but I found this on tech for you. Maybe it will help?
https://ls1tech.com/forums/conversio...-diagrams.html
1999 to 2002 Vortec PCM Pinouts
https://ls1tech.com/forums/3859121-post13.html
I believe GMT 800 Silverado's from
99-00 use terminal L
01-04 use terminals L and F.
05-07 Classic used Terminal F
http://www.qualitypowerauto.com/images/GM4PinPlug.jpg
I also found this S I L P connector view. http://i127.photobucket.com/albums/p...ese/cs130d.jpg
Hope this helps some.
Old 12-01-2013, 08:47 AM
I figured it out. no wiring harness, or operating system. i'm building a carbed ls2 this time around. I just ran one of the pins to a keyed 5v source. bingo.
this helps:
I just wish it said what the L and I terminals are for. I only hooked up the L pin to a 5v source. I left I alone. hopefully I don't burn anything.
Old 12-01-2013, 12:36 PM
11 sec. Truck Mod
TIM Z's Avatar
Are there any local Alt/starter rebuild shops that could tell you what each wire does ?
Old 12-01-2013, 12:39 PM
1FastBrick's Avatar
In the Diagram it shows the warning light hooked up to L.
Old 12-01-2013, 01:22 PM
the light is there to drop 12v down to 5v I believe. I had a 5v source so I skipped out on the light. a resister can also be used to drop the voltage.
Old 12-01-2013, 10:21 PM
Suburbazine's Avatar
Pink/Black might be your field duty cycle signal from a regulator, unless the alt has one built in. I don't remember the difference between 2 pin vs. 4 pin alts.
This is the 01-04 connector.
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
JordanH
10-03-2015 03:59 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Wrecker 426
09-30-2015 09:39 PM
Quick Reply: alternator wiring
