99 Silverado help
99 Silverado help
Just got hp tuners and wanted a little advice before I dive in.
I'm tuning a stock 99 with a 5.3 and I was kinda wondering what to hit engine wise? Is there any point in doing the ve tables on a stock truck? Anything I should know? I figured I'll adjust some trans settings, dull the knock sensors a touch and add a little timing. I've heard the 99s had problems with false knock as well. Any help is appreciated.
Remove some of torque management, and tune the ve table. Adjust your transmission shift points and go from there. I was amazed at how much better my truck ran just doing those things. I haven't added timing yet, but I don't really feel like I need to. My stock ve table was pretty crappy
Thank you. Probably remove all torque management and see how it feels. I just didn't know how close the ve table would be stock and I don't have a wide band on this one. But if there's gains I'll play with it
Stock MAF and VE should be pretty close, if everything is stock I'm not sure I'd change anything there.
You can remove some TM on the engine side for sure. Then I'd adjust all the power enrichment settings. Remove the long delays and lower the throttle enable percentage. Factory has like a 90% delay with a 5,500rpm delay. Lower those to like 1,500 rpm and 50-60% throttle so it picks up and goes a little quicker.
You should be able to lean out the commanded AFR during WOT too, they tend to run deep 11's AFR from the factory, going to 12.0 AFR with a no wideband should still be plenty safe. Quciken the shifts a little and add some shift pressure 5-10% or so.
