2000 Z71 gas mileage issues
#21
Registered User
My buddy drives like grandpa. Sets the ruise at 60-65 and just drives. I've seen it with my own eyes. I want to know how the hell he does it when I can only get 12-13 out of my truck in city or highway.
I starting to get the idea that these number are pretty normal for these trucks.
I guess I'll learn to live with it or sell it and 5.3 another s10 Zr2.
#24
Registered User
I'm just looking to get better than 12-13. I like my truck but with gas going upto 5.00 a gal this summer. My sonoma zr2 gets 16 in town and 18-20 on the innerstate.
#25
When i had a turbo on my 2000 EC 2wd with 3.42s and 275/60/16s 6.0 and 80E
i went to the south east texas track day and averaged 24mpg on 1100+ miles round trip
I had tuned it to lean out cruising and ran 93 Oct and babied it on the interstate at 70mph..
Now its back N/A with just a Isky 215 cam and im averaging 14.5-15 on my daily commute which is only 28 miles but the last 6 miles to work in the morning is idling on the freakin interstate goin 0-15mph and stopping.. it sucks badddd.
you never mentioned tire size or gear ratios... have you checked to see if your speedo is calibrated?
#26
My 99 rc 2wd would get 22 on the interstate. 3.42s and just cruising at 70. Headers, Cai, efans, and a handheld got it there. I've seen 23.2 out of it. And that's no bull. I've got witnesses. But then I threw it all away, went 4.11s, truetrac, cam, procharger...yeah...it gets about 15 now on a good day. And a good day is when I'm deathly ill and just putin around...haha!
#27
Registered User
Right now I'm running BFG 285/75R16 on factory rims. When the weather clears I'll put on the 277/55R20. I think I have 3.73. My Daily drive is around 3 miles on way.
I know this kills the milage because the truck never warms up, but even when I fill it up before and after along trip I still on get 12-13 mpg.
I am thinking of either getting the computer tuned or getting a bullydog programmer. A coworker has on for his Yukon and his milage when up from 12 to 14+ around town and close to 20 on the inerstate.
How and where do I get my speedo calibrated?
Where would I find a break down of the axle codes to verify my gear ratio. On an s10 I'm golden, but this is my first Silverado.
#28
11 Second Club
Well, right off the bat, a 285/75/16 tire is 2 inches taller so any MPG calculations with stock speedo calibration is incorrect. Not to mention, it's probably kinda doggy with nothing else done to it, really. And...BFG's are some heavy *** tires, especially if you have the Load Range E's.
The 275/55/20's should be the same height as your stock size 265/75/16 tires, but they'll surely be heavier, and MPG naturally suffers with heavier rolling resistance no matter how great the tuning is or isn't.
I calibrate my speedo by using a nice flat road, setting the cruise at 55 mph and comparing it to my GPS. I have yet to find any chart or graph that's 100% correct as far as simply changing to some generic numbers in the tune and it being "right".
With the speedometer not being calibrated, you're also driving a truck that doesn't have any of the shift parameters, torque converter lockup speeds, etc. not being anywhere near optimum.
I'd get it tuned now, and simply re-tuned when mods are complete. The stock tune on my own truck was nowhere even close to being optimum, and I can't imagine yours being so either...especially with taller tires than stock.
I've had 285's on my truck and 275/55/20's and both made the truck noticeably slower and less responsive. Common sense says that if the trucks takes more gas to get it going, which taller and/or heavier wheels absolutely will do, then mileage will suffer, period.
Good Luck.
Good Luck.
#29
I have a 01 4x4 z71 5.3 ecsb, full bolt on's and a BBP tune to 93, 33 1250 18 mud grapplers on rockstars. I average about 15.5-16 in interstate and about 12.5-13 in town.
The tune supposedly recallibrated the speedo but my gps and speedo read 2 different speeds when driving.
I have a few buddy's with the same truck at they all get around 12-16 in town. It's probably more how you drive then anything.
I actually get better if I make the truck shift about 2500rpm instead of babying it and shifting under 2k.
#30
11 Second Club
Maybe if your speedo was accurate, it might shift a little closer to your 2500 without manually shifting?
