1996 GMC Sierra W/no check engine light and can't read pcm
Hi...I have a 96 gmc sierra Stepside Z71 xc, 5.7/4wd/auto...I bought it 2 months ago and have been trying to figure out why when i start the car the ses light does not light and when i try to read my computer, my scanner says it can't communicate...I have used the scanner on my 96 suburban without problem, so i know the scanner is working...the truck seems to run ok...it had a 95 single cat exhaust with homemade o2 sensor ports wich i have since changed for the correct duel cat setup...I also noticed that the seatbelt warning light, key in ignition, headlight warning buzzer don't work either?? maybe coincidence?? I have checked all fuses and the wires all look in tact...I need help or i wont be able to pass inspection...any help you can give is greatly appreciated...thanks in advance...John
thanks, but tried it
hi and thanks for your quick reply, i did buy a pcm from ebay from a 96 tahoe with same motor and trans etc...plugged it in and no change...is there anything special you have to do when changing pcm?? after i swapped them, i didn't even notice and change in the way the motor ran and i assumed there should have been while the truck relearned its functions...thanks
Hi and thanks for your reply...I have checked all fuses and they are good, there is no power to the port, i was wondering if there was a relay or something that might have been unplugged or be bad...and i thought the ses light is an led...so it really can't burn out like a conventional bulb...I think it is more than a coincidence that the ses and port are both dead, just can't figure out why...thanks for your thoughts though...every little bit helps
I have been boggling minds from coast to coast...lol...the no ses light and port seem to be to much of a coincidence, i was hoping there was a trick to disable both and a fix to get em working again...can't really figure out why someone would do it though....thanks for your reply
