1990 chevy silverado tbi(I have a problem) help please? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 04-15-2009, 07:31 PM   #1
Default 1990 chevy silverado tbi(I have a problem) help please?
When I start up my truck it starts with no problem but at idle it has wierd miss and sometimes well most time when I throw it in revers it just dies...
any ideas?
Heres a few things that I have replaced in the last 2 weeks-
fuel sending unit including the fuel pump
wires
plugs
cap rotor
ign. coil
timing chain
every gasket possible
and then some....
any help would be greately app....
mr_montellano is offline   Reply With Quote
Old 04-15-2009, 08:46 PM   #2
11 Second Club
BadBandit69's Avatar
kinda sounds like a problem i had on my 87 tbi truck. Ended up being a broken knock sensor wire. Have you changed the starter recently? Lots of times the wire get unplugged of broken when taking the starter out.
Should be on the pass. side of the block towards the bottom. Mine had 1 wire going to it and if i recall correctly the wire was blue.
BadBandit69 is offline   Reply With Quote
Old 04-15-2009, 11:14 PM   #3
funny, but I just put a new starter last week.. thanks for the input I'll take a look at that tomarrow...
Old 04-16-2009, 09:54 PM   #4
11 Second Club
yea post up if that isn't it or if you have troubles indentifiying the knock sensor. I think i have one laying around somewhere i can take a pic of for you.
Old 04-20-2009, 10:24 PM   #5
well found a broken knock sensor and a bad connector, so I get both new and still have the same problem?
Thread Thread Starter Forum Replies Last Post
Help with LQ4 swap in 91 Z71 RCSB GrooveCityZ71 GM Engine & Exhaust Performance 7 08-31-2015 12:05 PM
3/5 or 4/6 mcgaughys drop kit 07-13 gmc/silverado GMCSIERRA5.3 GM Parts Classifieds 11 08-07-2015 01:50 AM
2000 Silverado fixed seat question Shtbox GMT 800 & Older GM General Discussion 2 08-02-2015 10:52 PM
4L70E shift problems ferrellrooster GM Drivetrain & Suspension 5 07-13-2015 09:53 AM
Carbed L's swap Trans Control davis28905 GM Drivetrain & Suspension 0 07-08-2015 03:20 AM
Tags
1500, 1990, 90, chevrolet, chevy, fuel, idle, knock, problem, problems, pump, sensor, silverado, starter, tbi, trouble
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
