Help! P0101, P0171, P0174
Old 11-24-2009, 10:04 PM
LS1Tech Whore
Dirty 30's Avatar
Default Help! P0101, P0171, P0174
My friend has a 2003 Silverado SS AWD bone stock with only a K&N OE replacement filter (stock tune as well). Its throwing a code P0101, P0171, and P0174. I logged it and sometimes it gets knock retard and sometimes it doesnt. I cleaned out the MAFS with MAFS cleaner but still runs the same. the CATS where replaced about 1 month ago as well but didnt help any. I also sprayed some carb cleaner around the vacuum connections and around the intake ports to check for vacuum leaks but didnt surge or anything.
I also checked the fuel pressure and at idle its 44 psi. At part throttle, it goes up to 50 psi. At wide open throttle, it shoots up to 56 psi and no more. When I turn it off, the fuel pressure goes down to 0 psi in about 2 minutes. I replaced the fuel pressure regulator on the fuel rails but still the same. I also replaced the fuel filter just in case.
Any help is appreciated!
-Jesse
(included are 2 logs)
File Type: hpl
File Type: hpl
Old 11-24-2009, 10:08 PM
GMCtrk's Avatar
03 should still be the return system right? If so, you should be seeing 55 psi at idle. If it's returnless it should be a constant 58-60 psi.
Old 11-24-2009, 11:07 PM
LS1Tech Whore
Dirty 30's Avatar
yes, its return style fuel rail.
Old 11-24-2009, 11:13 PM
GMCtrk's Avatar
Well it sounds like you need a new fuel pump. I'd stop driving the truck and replace it. It's not pretty when it goes out on the street like mine did. Truck just flat out died while driving.
Old 11-24-2009, 11:23 PM
LS1Tech Whore
Dirty 30's Avatar
Hmm... Would that cause P0101 to pop up?
Old 11-24-2009, 11:30 PM
GMCtrk's Avatar
that KN filter if it's oiled might be throwing oil onto the MAF
Old 11-24-2009, 11:47 PM
LS1Tech Whore
Dirty 30's Avatar
The filter is dry and I already cleaned the MAFS.
Old 11-25-2009, 10:00 AM
Truckshop's Avatar
looks like the pump is weak. you can get a p0101 if it stalls.
Old 11-25-2009, 10:14 AM
LS1Tech Whore
Dirty 30's Avatar
Do these return style trucks have another fuel pressure regulator in the gas tank?
Would a weak fuel pump cause the fuel pressure to go down to 0 after turning the truck off for 2 mins?
Again, thanks for the help guys! I read thru atleast 20 old threads and everyone seemed to check the same stuff like I did but at the end, no one reported back what the problem was for them.
Old 11-25-2009, 10:25 AM
LS1Tech Whore
Dirty 30's Avatar
When i reset the fuel trims at idle (they were at +25%), the truck runs very lean and hesitates. I left the fuel trim learn OFF and closed loop OFF and it runs lean as well.
Quick Reply: Help! P0101, P0171, P0174
