Diablo intune i1000, how good and safe is it?
the volant powercore filter really isn't that good... you're better off with their regular cone-type filter or a different intake... the powercore filter tends to make the trucks run pig rich at normal part-throttle driving....
and yes, you can do full data logging with the intune.. and I can definitely get you hooked up with a custom tune for it/your truck as well....
and if you're having idle issues, then something's up with the truck - the MAF or something else...
you have the stock GM maf on there right??? you don't want an aftermarket MAF sensor...
The cable that was referenced in 1fastbrick's comment was other tuners who send you the data cable to use to connect to your vehicle and allow you to load their cust tunes...the intune comes with its own cable....
LS1Tech Sponsor
Unplugging aftermarket stuff is not a bad idea...fuses should be fine.
So that's all I should unplug? My radio and sub's? Or should I do lights and other misc. Fuses, I don't want the tuner to lose power
