RSCB 05 Z71 Turbo
RSCB 05 Z71 Turbo
Sold!
Ok guys, I'm actually RE-listing my truck, again. I was seeking a trade last summer, but didn't come across one that I thought was fair and frankly I simply wasn't ready to sell it. With the help of PT, the truck recently ran a 10.91 @ 124.65, 1.67 60ft on the Michelin's it daily drives with. Atomic says there's more in it with slicks and I'm sure there is. DA was also highish (1500). I just never bothered investing in slicks as I never wanted to hassle with swapping tires. Hence, 4WD. I also couldn't justify the cost of a set of slicks given this truck has been to the track 3 times in 2 years. I won't go into the details in too much depth since my build thread has a lot of info in it, but yes this has been a very in depth build for me, and my theme has always been street sleeper. I built this truck for the local street races, and they got shut down just as the truck came together, so it has never even seen any street "action" which it was designed for. Changes int he last 6 months include: rear shock relocation with QA1 double adjustable's, brand new 4" mandrel exhaust with Vibrant resonator and j-tube (zero drone), and a new driver's side lower seat cushion,. It's a rust free CA truck. I purchased from original owner who bought from Chevy dealer in town. Tuned by Cunningham, Addiction, and Atomic at various stages of the way. Made 650rwhp/600rwtq on 15lbs. I have put over 15k miles on this build and would drive it anywhere. No whining from the rear end, no noises in the motor, belts don't chirp, it's extremely solid. Runs on E85, but I have a 6psi gasoline base tune which also runs well. The flex fuel sensor is installed and truck could be tuned for flex fuel, but I did not bother since I have E85 up and down the state and I've always used the Dept of Energy iphone app to find E85 stations throughout the state anytime I went on a trip. Truck has ~145k on body and ~15k on build. I have many many many more pics and vids which I can text to whoever is interested. Feel free to text me with questions at 805-765-1218. Not interested in any trades right now. Clean and clear CA title in hand. $18,250 OBO.
Turbo:
Trick Stage 3 kit w/ 76mm turbo
Stage 5 "Race" Intercooler
Hallman boost controller
Turbosmart 44mm wastegate
Precision 50mm BOV
DEI heat wrap/ cover everywhere where required
Motor:
Gen IV "big rod" 5.3L LM7
Tick Stage 1 turbo cam
ARP studs
862 heads milled for 10:1 compression, 3-angle valve job
GM LS9 gaskets
GM LS7 lifters
BTR trunions
BTR platinum springs
BTR pushrods
LS2 timing chain
Trick Flow timing chain dampener
Melling oil pump
Improved Racing oil cooler adapter w/ thermostat
Setrab oil cooler w/ Aeroquip lines
160* tstat
Elite Engineering catch can (motor does not drip or burn a drop of oil)
Gates tensioner, idler pullies
AC Delco motor / trans mounts
Exhaust:
Custom 4" mandrel bent stainless steel w/ Magnaflow muffler
Vibrant 4" resonator
2.5" "j-tube" to eliminate drone and resonance
V-Band joint at downpipe
ARP header studs
Driver's manifold gasket and collector matched, heat shield bosses smoothed to allow DEI heat wrap.
Fuel:
Holley rails
ID1000 injectors (As preventative maintenance, I sent the injectors in to RC Engineering for flowtesting and ultrasonic cleaning @ 10k miles, flowsheet will be included)
Aeromotive "next generation" A1000 regulator
PTFE -8/-6 return fuel system
Dual pump system with twin Walbro 450's
Fuelab E85 compatible stainless inline filter
Continental ethanol sensor
Drivetrain:
4L85e, Transgo HD2, Circle D 2B 3200 stall
Circle D flexplate
Eaton Tru-Trac, 3.42 gears
Mosier diff cover
Spicer u-joints all around
MWD 31 spline transfer case input shaft
MWD saver for transfer case
Completely rebuilt front diff
New CV axles
Tru-Cool 40k w/ Aeroquip lines
Cal-Tracs
Suspension:
Atomic/ QA1 front coilovers
Rough Country tie rod sleeves
New GM inner/ outer tie rods
Moog front upper control arms
Moog front lower control arms
Belltech offset upper control arm bushings
Belltech hangers
Belltech shock extenders
VAS Rear Shock Relocation brackets
QA1 Rear Double Adjustables
Gauges:
Innovate SCG-1 all-in-one boost / AFR gauge
Twin Aeroforce gauges
Automer fuel pressure sensor wired into Aeroforce
Wheels/ tires:
Centerline "Voltage II" 18x8
Michelin 265/60/18 tires
Misc/ Maintenance:
New front driver's seat cushion
AC Delco radiator
AC Delco a/c condensor
AC Delco power steering pump
Bluetooth added to stock deck
Rockford Fosgate front/ rear speakers
New battery
NNBS starter
GM bedliner
New GM battery tray
New GM rear bumper and all new plastics (originals were dinged/ unsightly)
Sylvania Silver-Star Headlight bulbs
Extra Parts:
Stock Z71 Fender Flares
Turbo:
Precision 50mm BOV
Motor:
ARP studs
GM LS9 gaskets
GM LS7 lifters
BTR trunions
BTR pushrods
LS2 timing chain
Melling oil pump
160* tstat
Exhaust:
ARP header studs
Fuel:
Holley rails
Drivetrain:
Circle D flexplate
Mosier diff cover
New CV axles
Cal-Tracs
Suspension:
Belltech hangers
Gauges:
Wheels/ tires:
Misc/ Maintenance:
AC Delco radiator
New battery
NNBS starter
GM bedliner
New GM battery tray
Extra Parts:
Bluecollar Hotrods (10-03-2017)
Last bump before eBay! Truck is rock solid reliable and I would not hesitate for a moment to drive it cross country. I have put over 15,000 miles on this build as my DD for the last 2 years and any kink or bug has been thoroughly ironed out along the way. Ice cold a/c, hot heat, tunes, and 10s at the flick of the push button 4wd switch.
Low boost 10psi run:
Walk around:
Walk around:
