FS: Turbo 2005 RCSB Z71, 4L85e, Circle D, Trick 76mm, 650rwhp/600rwtq
Old 09-09-2016, 05:34 PM
lxcoupe's Avatar
Default FS: Turbo 2005 RCSB Z71, 4L85e, Circle D, Trick 76mm, 650rwhp/600rwtq
Guys, I'm putting my truck up for trade towards a V2 CTS-V. I hurt my back earlier this year which is still giving me issues and I'm ready to shift gears into something more plush. I've been driving a friend's boaty Marauder the last couple months and it's got enough power to get me around day to day. I'll consider trades for something 4-door, RWD, V8. Impala SS, Chevy SS, TBSS, etc. Cash on your end or my end.
This truck has been my DD for the last ~16 months and 15k since the turbo went on. It is rock solid reliable. ~145k on the chassis. Ran 11.65 @ 120 on a very hot night and spun to a 1.91 60ft. Ran a 1.72 60ft the first track outing. I have about 10 passes on the truck, always on street tires and trying to figure out the launch. If I had known to air them down, I probably could have gone 1.6x and lower 11s. With 18-20lbs, colder air, and Hoosiers at all 4s, I know it can go 10.x (this will be my plan if I end up keeping the truck). It currently makes 550/580 on 10lbs and 650/600 on 15lbs. The truck runs on 100% E85 since we have it around here, but it can retuned for pump gas. I drove around on 6psi on CA 91 on my tuner's base tune and the truck ran great and was still very fun. Speaking of tuning, this truck has a lot of dyno time, both at Cunningham Motorsports as well as Addiction Motorsports, as well as Atomic's email tuning. Zero driveability issues. No surging or bucking. Starts immediately on E85. Absolutely zero leaks anywhere.
Turbo:
Trick kit w/ 76mm
Stage 5 "Race" Intercooler
Hallman boost controller
Turbosmart 44mm wastegate
Precision 50mm BOV
Motor:
Gen IV 5.3 LM7
BTR Stage 1 turbo cam
ARP studs
862 heads milled for 10:1 compression, 3-angle valve job
GM LS9 gaskets
GM LS7 lifters
BTR trunions
BTR platinum springs
BTR pushrods
LS2 timing chain
Trick Flow timing chain dampener
Melling oil pump
Improved Racing oil cooler adapter w/ thermostat
Setrab oil cooler w/ Aeroquip lines
160* tstat
Elite Engineering catch can
New Gates tensioner
DEI heat wrap/ cover everywhere required
Exhaust:
Custom 4" mandrel bent stainless steel w/ Magnaflow muffler
Fuel:
Holley rails
ID1000 injectors
PTFE -8/-6 return fuel system
Dual pump system with twin Walbro 450's
Fuelab E85 compatible stainless inline filter
Continental ethanol sensor
Drivetrain:
4L85e, Transgo HD2, Circle D 2B stall (stalls to about 2800 on my setup)
Circle D flexplate
Eaton Tru-Trac, 3.42 gears
Mosier diff cover
New Spicer u-joints all around
31 spline transfer case input shaft
Case saver for transfer case
Tru-Cool 40k w/ Aeroquip lines
Cal-Tracs
Suspension:
Atomic/ QA1 front coilovers
Rough Country tie rod sleeves
New GM inner/ outer tie rods
Belltech hangers
Belltech shock extenders
Calvert 9-way adjustable rear shocks
New Moog front upper control arms
New Moog front lower control arms
Belltech offset upper control arm bushings
Gauges:
Innovate SCG-1 all-in-one boost / AFR gauge
Zeitronix ethanol content gauge custom installed into cluster
Twin Aeroforce gauges, 1 custom mounted
Automer fuel pressure sensor wired into Aeroforce
Wheels/ tires:
Centerline "Voltage II" 18x8
Michelin 265/60/18 tires
Misc/ Maintenance:
AC Delco radiator
AC Delco a/c condensor
AC Delco power steering pump
Bluetooth added to stock deck
Rockford Fosgate front speakers
Front diff rebuilt w/ new bearings/ seals
New front axles
New battery
NNBS starter
GM bedliner
New GM battery tray
New GM rear bumper and all new plastics (originals were dinged/ unsightly)
Sylvania Silver-Star Headlight bulbs
Many more pictures in my build thead:
https://www.performancetrucks.net/fo...k-76mm-535991/
Edit:
Here is the 3" exhaust that is included, if the buyer wants it:
Old 09-09-2016, 05:51 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Out of curiosity, what size is the pipe going to the Throttle Body? I didn't see it listed in your build thread.
Old 09-09-2016, 05:53 PM
lxcoupe's Avatar
3"
5" Race intercooler kit.
Old 09-09-2016, 05:59 PM
1FastBrick's Avatar
Thanks!
Old 09-09-2016, 06:06 PM
lxcoupe's Avatar
Thanks!
No prob
Old 09-10-2016, 10:56 AM
GMCtrk's Avatar
how does the A/C work?
What gas mileage does it get
converter is single or triple disk?
What are the specs/brand on the turbo?
Old 09-10-2016, 12:02 PM
lxcoupe's Avatar
A/C is ice cold. The intercooler piping routes under the radiator so it doesn't interfere with the condenser.
10mpg avg city with wot blasts mixed in, 15mpg highway. It has a 350+ mile range on one tank of E85 on the freeway.
Circle D single disc 258mm "2B"
It's the 76mm off shore turbo from the Trick stage 2 kit.
Old 09-11-2016, 03:08 AM
MadDMax66's Avatar
How many miles are in on the engine and trans since build?
Do you have documentation on them both?
How's the chassis look? rust?
Whats the history on the truck before you owned it?
Very neat build, definitely interested.
Old 09-11-2016, 01:12 PM
lxcoupe's Avatar
Chassis has ~145. Original Gen IV shortblock. I do have receipts for the cylinder head work and all the parts, yes.
Trans is a 4L85e. I put the shift kit in when I installed it. I've had the pan off several times since then and the magnet is always clean. Shifts completely perfect and I'd welcome anyone to come take a ride to verify.
Chassis is typical Southern Caifornia. No rust, no problems.
I'm the 2nd owner. Original owner bought it from Paradise Chevrolet here in town.
Thank you. This isn't the fastest truck on the forum but it has a lot left in it and it can be driven anywhere. At this point I'm primarily looking for trades, to be honest.
Old 09-13-2016, 02:52 PM
MadDMax66's Avatar
Can you post up some pictures of the interior, undercarriage, bed, etc. when you get a chance. Thanks
