Wolftrk99 and 1FastBrick can't stop BSing thread...
#143
Custm2500's Rude Friend
From what I could find, there right at .480 lift but no one could confirm duration or LSA.
If I had access to one I could have it checked on a Cam Doctor. Supposedly this is the Oem part number for the cam you mentioned. 12625436
I did find this cool article though that I thought I would share...
http://www.enginebuildermag.com/wp-c...0000054947.pdf
As for your last question, You would probably loose a little power.
You could have it re-ground though to get a little more out of it...
#145
Because I said so...
I am just guessing that the fact that the HP rating is higher on the newer vehicles that you might lose power. Not to mention the 99 was the smallest of the cams. Of course they went to a flat top piston so who knows... As you can see with the specs I have found, they are fairly similar between the years. I can't imagine the DOD or AFM cams are much different.
4.8/5.3L LM7 LR4 L59
99 12560966 191/190 .457/.466 115.5
00-06 12560967 191/190 .457/.466 114
L33 5.3L
05-07 193/193 .479/.479 116
LQ4
99-00 12560967 191/190 .457/.466 114
01-06 12561721 196/207 .467/.479 116
LQ9
02-06 12561721 196/207 .467/.479 116
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration 0.496" / 0.496" int/exh lift 116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration 0.467" / 0.479" int/exh lift 116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration 0.525" / 0.525" int/exh lift 116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration 0.551" / 0.547" int/exh lift 117 LSA
LS2
204/211 0.525/0.525 int/exh 116 LSA
Look at this article. Kind of a neat comparison on factory cams.
Look at the bottom of the article where the LSA cam is compared to the LM7. I wouldn't be surprised if that cam was the same as the AFM cam.
LS Cam Test Comparison - Car Craft Magazine
L33 5.3L
LQ4
LQ9
1998 - 2000 Fbody
2001 - 2002 Fbody
2001 LS6 cam
2002+ LS6 cam
LS2
mhotrodscooter
12-21-2015 02:39 AM
Jaxon2580
38
11-06-2015 01:39 AM
