New dd/side project
New dd/side project
I haven't posted too much on here in the past couple weeks, but I finally got rid of my black truck. Ended up getting lucky and trading it for a 98 z28 with 124k miles. The car is pretty much stock other then the free ram air mod, the throttle stop mod and an slp loudmouth which I'm still getting used to. Car runs pretty good other then having 20-30 lbs oil pressure at idle. PO said it will need new cam bearings so when I get out of the Marines ill just pull the whole engine, replace all the bearings and seals and do cam and springs, ls6 oil pump and an ls2 timing chain. Thinkin somewhere around a 228/230 duration cam. I'll need it to pass smog so I don't want it too crazy. Most of these pics are from two weeks ago when I got the car
