any smart small engine/atv engine guys here?
Old 10-05-2015, 09:51 PM
TXsilverado's Avatar
Default any smart small engine/atv engine guys here?
I have a question about the 800CC engine on my 2012 RZR.
the internet says my compression pressure should be between 165&185. Mine checked out at 130psi on each hole which prompted me to do a leak down test. leak down on both cylinders is between 4&5% which is in the green zone. the gauges I was using only showed around 35-40 psi to get the leak down gauge to zero...I expected it to be around 100psi but if the gauges are made to work together...I guess so.
soooooo WTF? low compression test but perfect leak down? the valves are not adjustable on this motor. do I just say screw what the internet says and trust the leak down results, or should I be worried about the low compression pressure?
Old 10-05-2015, 10:23 PM
03sierraslt's Avatar
Did you spray a **** load of nitrous and bend the rods stew? Lol
Old 10-06-2015, 12:56 AM
8 Second Truck Club
Blown06's Avatar
I do some small engine work if you wanna leave it with me for a few days.
Old 10-06-2015, 08:17 AM
Ill trade the rzr for your truck for a weekend
Old 10-06-2015, 12:58 PM
Gadgetized's Avatar
When you did the leak down test was the piston at the bottom of the cylinder? If you compressed it with air, the air would rotate the piston down unless you had it at TDC. TDC is where a cylinder wears the most, so rotate the engine to TDC and do a leak down test there.
Old 10-06-2015, 06:00 PM
engine was at TDC
Old 10-06-2015, 07:30 PM
Hunt&Fisherator
silver-mod-o's Avatar
Try another gauge and repeat the compression test... But honestly, if it were mine and still made good power and the two cylinders were real close balance-wise, Id run it.
Old 10-06-2015, 08:15 PM
they are about as identical as they can be on both compression and leak down. for those that don't know, my machine spent around 30 minutes 20' deep in the san jac river a little more than a week ago. engine cut before water made it to the cylinder.
Old 10-06-2015, 08:17 PM
13 Second Truck Club
trxmxzx's Avatar
What gauge you using? I've had gauges vary 5- 45psi diff.
I know your good with your tools just giving ideas to look at
Old 10-06-2015, 08:43 PM
not sure what brand. I borrow them from a friend because I don't use them enough to justify buying. probably harbor freight lol.
Quick Reply: any smart small engine/atv engine guys here?
