Helping a friend out and getting some more suggestions.
92 accord will cut out at high rpm and die on occasion. Going to check Fuel pressure incase it's the pump or FPR and the grounds.
anything else you suggest?
Ignition module? You can have it tested at any local oreillys. Does it ever have problems starting when warm? Does it have these problems after a cold start or only once warmed up?
From what I know when I talked to him earlier it does have trouble starting some times. Did not say if its a warm or cold issue.
He talked to a shop and they said there is no place on the rail to check the Fuel Pressure. Any tips to that?
