TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Pretty positive I lost the motor last night.
Old 12-24-2013, 02:49 PM
  #21
Laid Back
Beatdown Z's Avatar
It most likely spun the #6 rod bearing and that shouldn't cause any permanent damage to the block.
The same thing happened to a TBSS I bought. There was some slight scoring on the 5&6 cylinder walls from the metal that was slinging around. I went the extreme budget way and just gave the cylinders a light hone with a drill and a three stone hone and slapped some new rings in.
I think you can bore the LS2 blocks as far as .020" over, so you could go that route if you want it done right.
Old 12-28-2013, 10:04 AM
  #22
JustAGoat's Avatar
Same thing happened to my Aero. Number 6 rod bearing...
You can fix it cheap just like Beatdown Z is describing or like my friend did with mine and stroke it.
Old 12-28-2013, 08:26 PM
  #23
Mrs.KCodd's Avatar
Im figuring it will be getting a stroker kit and a turbo. Will the factory pump and injectors support 700hp? Im figuring on leaving the stock heads on and doing an ls6 intake. The cam is still to be determined and Im not sure on tb size yet. The motor is getting dropped to the machine shop Monday.
Old 02-13-2014, 01:32 PM
  #24
JustAGoat's Avatar
No they will not support 700HP. I'm limited to 620 HP AWD on a 340 LPH pump. I think they say that same pump can do close to 700HP on a RWD truck. Would probably need at least 60 lb injectors also. I have a set of 72's on mine.
shawn96gmc
05-17-2016 04:15 PM
kyle's v
10-04-2015 12:37 PM
1slwgto
08-16-2015 06:40 PM
KOOKS Headers
07-27-2015 01:43 PM
atxlt
07-20-2015 11:06 PM
Quick Reply: Pretty positive I lost the motor last night.
