TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
had the TBSS one week
Old 01-23-2013, 09:18 AM
  #21
TXsilverado's Avatar
wow....260!!! i got an oil pan, windage tray and pick up tube along with all hardware for 130.
Old 01-23-2013, 06:18 PM
  #22
05RST2NV's Avatar
Dang where did you find that and what pan are you running?
Old 01-30-2013, 09:56 PM
  #23
Laid Back
Beatdown Z's Avatar
Subscribed!
Just bought an AWD TBSS that is a knockin'. If there's anything i can do to prevent it from happening again, i'm all game.
Old 01-31-2013, 05:04 AM
  #24
05RST2NV's Avatar
Go to tbssowners.com they have alot of info! If your a awd drive guy im sure your motor is a victim of the oiling problem, i suggest getting the updated pickup tube pcmforless has.
Old 01-31-2013, 09:46 AM
  #25
Area47's Avatar
run 7 quarts of oil in it.
Old 02-03-2013, 06:00 PM
  #26
Laid Back
Beatdown Z's Avatar
Registered on TBSSowners and damn, a lot of blown up engine threads over there!
Old 02-04-2013, 07:35 AM
  #27
06 4.8's Avatar
What he said! This is im doing with mine and no more oil psi drop on launches
Old 02-09-2013, 07:58 AM
  #28
05RST2NV's Avatar
Good info!
Old 03-09-2013, 01:52 PM
  #29
formerly 2004RST (changed 11/19/2012)
OneQwikSS's Avatar
Originally Posted by 05RST2NV
After reading all the post on here I found this: Relocated Oil Pump Pickup Tube Kit
I'll just go with that rather than a new pan.
something tells me that i talked to someone about doing JUST the pickup tube fix & there was a reason why you want to change the pan & crossmember over just the pcmforless fix...IDR what it was but i have a **** memory so god knows what the reason could be....
also if you change the oil pan to the c6 ls2 pan you have to change the engine crossmember & you can get that from leftcoast32.com
(not trying to violate any forum rules by posting another vendor that may, or may not, be a vendor to this site...just trying to help fellow TBSS owners)
Old 03-09-2013, 10:07 PM
  #30
Laid Back
Beatdown Z's Avatar
The stock pan has a 50psi bypass built into it. I'm going to make my own pickup tube and block off the bypass. That way i don't have to dick around with crossmembers or A/C compressor mounts.
As for the crossmember kit for the C6 pan. Just take a sawzall to the stock crossmembers and let er eat! Not like it's going to fall apart or anything.
Quick Reply: had the TBSS one week
