TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Upgrading the 2004 work horse
Old 04-23-2015, 08:16 PM
  #21
In-Zane Moderator
ZONES89RS's Avatar
Yea, that's why I want the 114, between the 6 liter cubes and wanting the power to pull through the rpm a little more.
Old 04-23-2015, 08:36 PM
  #22
TXsilverado's Avatar
oh I figured you would want all power down low in a 5600 lb workhorse. carry on. it'll be better than stock either way.
Old 04-23-2015, 08:55 PM
  #23
In-Zane Moderator
ZONES89RS's Avatar
I want to stretch it out further. All the power down low would just be best with a stock cam.
Old 04-23-2015, 09:17 PM
  #24
GMCtrk's Avatar
I've only had 2 cams in my 6.0 aside from stock so not a huge sampling, however, my current 212/212 112 doesn't really feel any stronger down low than the 222/226 113 I had previously. And the larger cam had noticeable more pull up top I believe. The larger cam had more aggressive lobes though and I ended up busting a PAC beehive spring.
So if you really want to get more on the top end, you may want to step up to a low 220s cam. Zippy previously described the 212/218 in a 6.0 as like stock but more. A pretty similar powerband.
Old 04-23-2015, 09:45 PM
  #25
Fast_six oh's Avatar
What i thought as well..to the OP...the BTR truck cams look pretty good..thinking about a stage II for my lq9
Old 04-25-2015, 09:31 PM
  #26
In-Zane Moderator
ZONES89RS's Avatar
If I was not doing so much, more cam options would be considered. But new head gaskets, the cost of a used 6 liter, headers, tune, valve springs, ect. All of these things are eating up too much funds so used is the option.
Old 04-26-2015, 09:20 AM
  #27
What went wrong with the old lq4? If youre buying a doner, let me know when the blown short block is ready to go. I might be interested.
Old 04-26-2015, 10:36 AM
  #28
In-Zane Moderator
ZONES89RS's Avatar
Locked up. Not sure why. Still full of oil. Going to pick up the short block right now.
Old 04-26-2015, 01:00 PM
  #29
In-Zane Moderator
ZONES89RS's Avatar
Hell with it, found a hot cam.
Old 04-26-2015, 01:50 PM
  #30
In-Zane Moderator
ZONES89RS's Avatar
Picked up my 6 liter short block today. Was freshened up. Hopefully it's is a solid engine.
Quick Reply: Upgrading the 2004 work horse
