TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Improved bump stops??
Old 03-30-2015, 12:59 PM
GM1697's Avatar
Default Improved bump stops??
I'm just thinking out loud here, so shut me down if I'm completely wrong.
I level my truck using the torsion keys. This obviously raised the lower bump stop further away from the lower control arm, to the point that there is about a half inch gap. And therefore my ride became stiffer.
For those who aren't aware the factory bump stop actually acts as a "damper" and under factory conditions it will continually make contact with the lower arm.
So here is my thought,
Can I buy longer, more progressive bump stops somewhere, that could contact my lower control arm at the current leveled height? Thus restoring the cushioning affect that is produced at stock height. I'd ideally just need a bump stop that's half inch taller.
Is this reasonable thinking?
Old 03-30-2015, 01:36 PM
Vortec350ss's Avatar
Having bump stops in contact would stiffen the ride at this point. Part of your problem is that there is much less downward travel on the suspension the way you are set up. The torsion keys basically enabled you to increase spring rate while raising the front of your truck. The bump stops help the torsion bars at the stock setting because they are 'looser'. Basically bump stops only make the suspension more stiff and in effect increases their spring rate as the suspension travels downward.
What you could be feeling is the a arm hitting the bump stops with more momentum and force as they travel through that gap you have created. In that instance its possible they would help... but I'm not sure.
Old 03-30-2015, 11:17 PM
GM1697's Avatar
Thinking about it more, and considering what you said, I guess it is unreasonable to think that bump stops would make a difference at this point. Because the stiffness is caused by the actual torsion bars being "tighter" now and not the lack of bump stop contact.
Old 03-31-2015, 08:25 AM
I have a gauge for that
Atomic's Avatar
With my coilover swap I cut off the bumpstop pocket and drilled a hole through the LCA and mounted a universal bump stop there. They make many different sizes so you can buy a longer one and trim it as you like. It may help, but coilovers would definitely help your ride
Old 03-31-2015, 01:57 PM
GM1697's Avatar
I've been dying to buy your mounts, the cost of the coilovers just kills me. All said in done I think I figured it would end up costing about 700 bucks
Old 03-31-2015, 01:58 PM
Atomic's Avatar
Yea, thats about what it costs. Worth it if you ask me, but I am probably biased lol
Old 03-31-2015, 10:22 PM
GM1697's Avatar
haha probably, but it is on my to-do list. Cam comes first
The thought of some bilstein coil overs sounds so nice too..
Old 05-03-2015, 06:21 PM
2002_Z28_Six_Speed's Avatar
I have longer stiffer bump stops and it did work for me. I am thinking about trying out Atomics brackets, though. That is as soon as I get my motor back together.
Old 05-04-2015, 09:33 PM
GM1697's Avatar
You have a part number or a link??
Old 05-05-2015, 10:06 AM
If you want an exact link I can PM you (non-sponsor link policy?)
But basically if you look up Timbren Suspension Enhancement System -- it will show the dealers you can order from. The fronts made a big difference in the ride. The rears didn't give me as much improvement.
They were 200 bucks but I went for it anyways because on the Yukon you don't have many options for torsion bars and I wanted to make the front ride stiffer.
SloSVO
11-22-2020 07:34 PM
Vortec350ss
01-12-2016 10:36 PM
lukn4trbl355
10-21-2015 11:19 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: Improved bump stops??
