60e to 80e neutral switch
Help guys. I been research. Not sure if I'm doing right. Since my truck is 2006. So the 4l60e is 2006 so from that neutral safety switch to 2000 4l80e on my 06 Silverado. So it will work or have to do something with neutral safety switch. Let me know thanks.
Great. One question I haven't pour trans fluid in new tranny. Haven't crank up since heads are off right now. I nocited when I shift to park it does move roll truck. Had to put emergency park brake. Is something wrong with transmisison or need fluids pour in?
Found it was set reverse. Shift linkage was fall off. The bracket no good. I have to order. I push park. It's locked no rolling truck. Now I have problem for trans dipstick nowhere bolt the dipstick bracket. Cause the 80e model is 2000. Can you help me what to do with dipstick.
You can see in this picture, it bolts to the stud/bolt right above the dowel pin hole in the bellhousing.
I always install them while putting the trans in place so much easier, but they can be installed once in and all bolted up, it just takes some patience. I recall going from the top, and angle it all crazy to get it down in and turning it to the right, and having the passengers side inner fender out to help guide it with the other hand.
2002_Z28_Six_Speed
10-04-2015 01:34 PM
Wrecker 426
09-30-2015 09:39 PM
