TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
14BSF Gear Pattern Check
Old 09-22-2014, 08:00 PM
Jeebalow's Avatar
Default 14BSF Gear Pattern Check
I am rebuilding a 14 Bolt SF axle. I ran a pattern and would like another set of eyes to take a look. It seems to me that I should add shims to the pinion due to the drive side pattern on the gear. Second questoins is how much should be added at a time 0.005"? Here are some pics of the pattern.
Coast Side
Drive Side
Opinions please.
Old 09-23-2014, 09:34 AM
Jeebalow's Avatar
Received an answer on another forum and though I would update this for completeness:
Originally Posted by axisT6
What gear ratio is that? What shim do you have under the pinion under the pinion now? What is your backlash?
These are Yukon 4.88 on a Trutrac with a 0.030" pinion shim and backlash at 0.007"(spec is 0.005-0.008"). I got them from axisT6 last year and just now getting around to gearing.
And just to make sure the info is complete, here is his response in the gear install how to thread:
Add 0.002" to the pinion depth, double check backlash. The pattern is great, just a little high.
I'll add that and run another pattern and report back. Thanks axisT6!
Stainless Works
04-10-2016 04:34 PM
ALL ULL C
08-16-2015 08:56 PM
1slwgto
08-16-2015 06:40 PM
Stainless Works
08-04-2015 12:56 PM
iregret
07-27-2015 10:32 PM
Quick Reply: 14BSF Gear Pattern Check
