TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Getting dents out of pipe.
Old 08-07-2012, 02:58 PM
wheeliE-maxx's Avatar
Default Getting dents out of pipe.
My driveshaft left three of these beauties behind as it made it's departure. Probably no power hit, but it seems to sound a bit different. Might just be my imagination. I could cut the pipe down, cap the ends, and freeze water in it like you would a two stroke expansion chamber. Weld it back together later in my fabrication class. I don't think pulling on an attached stick welding rod would work (Herculean force required). Any other ideas on what I could do?
Old 08-07-2012, 04:22 PM
KickinAssAndTakinNames
colekill's Avatar
maybe rig up some sort of slide hammer. tack a long welding rod on with a sliding weight(the head of a hammer without the handle) and some sort of plate on the end that when struck would Pull up on the dent.
Old 08-07-2012, 04:41 PM
outlawz2004's Avatar
a slide hammer and a torch to get it hot would probably work.
Old 08-07-2012, 04:44 PM
TXsilverado's Avatar
cut out a 3" section and weld in a new piece of pipe.
Old 08-07-2012, 05:21 PM
Thanks for the help guys.
Old 08-07-2012, 05:33 PM
Custm2500's Rude Friend
1FastBrick's Avatar
The dent fix type stud guns work well.
Old 10-16-2012, 08:19 PM
TG02Z71's Avatar
Maybe try the heat and cold air trick thing?? it maybe will pop out. like body shop guys have done.
Old 10-16-2012, 08:25 PM
Baltimore Whore
Mangled03gmc's Avatar
Im with TX, cut it out, weld new metal in, or the torch, slide hammer should work fine also
Old 10-16-2012, 08:37 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Is that a Cal Speed tailpipe?
Old 10-16-2012, 08:46 PM
Baltimore Whore
wait for it.........wait for it......... BAM
Quick Reply: Getting dents out of pipe.
