3D Printing
Formerly ScreamingL
Here's some stuff I have been working on. Everything I do is designed on AutoCADD and printed with a MakerBot Replicator 2.
Gauge pods for the cubby / airbag switch location. 1-1.5 hour print times
I have a 52mm design and a NX controller design.
Also designed a switch plate to replace the snap in plate under my radio, plate took 25 mins.
1 Post
If only I actually had access to the software at home or work to really utilize it. Was offered the training so I couldn't say no but I don't have any way to use it unfortunately
Resident Retard
Yeah when the wife and kiddo go to sleep i just sit up and nerd out on this stuff. Trying different things... You should download it and try it out, i bet you would love it...
Here is a revised Velocity stack thingy. This one is a little bit more beefy. I am gonna get it printed in a ABS like plastic that is for High Temp, rated at 500* F
Check out the softened edges.... I plan to drill out those bosses and install a helicoil so i can attach it to a heat shield thingy.
