Passing emissions test with trick turbo kit.
It all depends on where you are. Some areas just look for the minimum (horn turn signal brake lights etc.) some will put a sniffer in your exhaust and others will just hook up to the OBD II port
All the businesses I have ever had emissions testing has discontinued doing the sniffer / roller test, and I made an (incorrect) assumption that the sniffer test should be gone. That was wrong because I hadn't done the math.
Roughly in another 5 years, and all pre-ODB II vehicles should be past requiring any emissions testing, at least in Texas, and most states that perform an emissions test. You are on your own if you move to California.
