Motorhead Garage Installs a B&M Transmission Cooler
Video:
Motorhead Garage Installs a B&M Transmission Cooler - YouTube
In this video, Sam and Dave show you how to install a B&M Hi-Tek SuperCooler. They used a Camaro in the video, but the installation procedure for a truck is going to be pretty much the same.
Heat can kill a transmission. A transmission cooler will give your trans a longer life when towing or using your vehicle for performance. B&M's Hi-Tek SuperCooler is pressure tested up to 200 psi and comes with a complete installation kit.
B&M Hi-Tek SuperCoolers are 100% aluminum stacked plate style core which is ideal for additional transmission cooling. With oven brazed construction this sturdy cooler design is practically impervious to flying rocks or other debris.
