DIY 99-02 Efan Swap Tech Info
#23
When you swap from a 99-00 OS you need to make minor changes to the calibration so you don't get a false check engine light.
99-00 is wired different from 01-02 for the charging system.
Only inferior tuning products require that...
#24
And? IIRC, correcting this entails nothing more than turning off a single DTC.
For efans on 99-02: 01-02 OS, F-body fan settings (customize on/off temps to your desire), 145a alt, and OEM harness with appropriate pinning. Yes, you don't have control of the fans based on a/c pressures, however I have yet to encounter a single problem without them. Some have wired in switches to turn on the fans manually, which is also fine.
#25
99-00 are wired with 1 wire 01-02 use 2 wires. you have to change them from on to off as I mentioned before.
#27
99-00 OS charging
01-02 OS charging
These are Stock tables in EFI Live you have to modify the 01-02 to look like the 99-00 by turning off the F terminal
The HPT table is similar but uses 0 for OFF and 1 for ON.
randybill (04-05-2018)
#28
I suggest adding in a delay on Fan #2 to help from burning up wiring and/or relays... I noticed that if all the conditions were set to turn both fan 1 and 2 on at the same time the load the fans pulled was like 20+ amps (measured with a clamp meter) with the 05+ efans. I would burn up a relay every 6 months. That delay allows fan 1 to turn on and get the fans up to half speed, then fan 2 kicks on and the fans don't draw as many amps since they are allready turning..
Attachment 85195
Attachment 85196
Attachment 85195
Attachment 85196
#30
what OS to use?
just finished wiring in my 05 efan harness into my 2000 ecsb 1500. fans turn off on with HP tuners fine. it'll be ahwile before I get the truck running to actually test fans that way.
fastbrick mentioned a newer os? I have no problem spending more credits if my fans will work. please advise. longtime listener on here.
ETA: more searching tonight revealed that 1fastbrick has already written about this.
https://www.performancetrucks.net/fo...h-info-536648/
Last edited by randybill; 04-01-2018 at 09:17 PM. Reason: added link for others to follow
