Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL TRUCK PERFORMANCE, PROJECTS, & GROUP DISCUSSION...specifically > STEREO & ELECTRONICS
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 10-03-2009, 08:25 PM   #1
Trader Rating: 5
mred's Avatar
Question wiring factory stereo to amp?
what do i need to wire up my factory radio to the amp.
i have rca inputs but where is the rca outputs on the factory radio?
do i need to wire some in?
thanks
Ed
mred is offline   Reply With Quote
Old 10-03-2009, 08:33 PM   #2
Trader Rating: 7
Where's the Beef?
viciousknid's Avatar
Send a message via MSN to viciousknid Send a message via Yahoo to viciousknid
It likely doesn't have RCA Out. You can wire them into the the Rears. Run your Remote wire from the amp to the radio. Should say Power Antenna or Accessory. Really any wire that is Hot when On and not when Off.
__________________
-Joshua
'03 408 ECSB|244/248 612/615 112|LT ORY XR1|FLT4|COS3 SD EFI Live|Circle D 3000 stall|4.30's|truetrac
To Err is Human. To ARRR is Pirate.
viciousknid is offline   Reply With Quote
Old 10-03-2009, 08:43 PM   #3
Trader Rating: 5
mred's Avatar
Quote:
wire into the rears?
meaning wire the new rca jacks into the rear speaker wires?
Old 10-03-2009, 09:02 PM   #4
Trader Rating: 7
Where's the Beef?
Yes. Basically.
You need an audio feed and without an Output RCA from your stereo you will only get that feed from your front or rear speaker outputs.
You can get some of these and tap into it.
__________________
-Joshua
Old 10-03-2009, 09:07 PM   #5
Trader Rating: 5
mred's Avatar
Yes. Basically.
so if i want to run the door speakers also,do i run a different amp and tie in another set of rca jacks into the different amp?
Old 10-03-2009, 09:14 PM   #6
Trader Rating: 7
Where's the Beef?
You confused me. If you tap into the speaker with the rca wire you will have 2 wires going to the speaker and 2 wires converted to RCA for the amp. All your doing is tapping into the feed. NOT completely cutting it off from the door speaker.
You CAN change out your door speakers and add an amp if you want but I personally wouldn't bother.
__________________
-Joshua
Old 10-03-2009, 09:18 PM   #7
Trader Rating: 5
mred's Avatar
i understand about tapping into the door speakers,but i do have aftermarket in the doors also.
but to get all the door speakers amplified how do i go about it then?
do i just tap into the front speakers as well and run them to the amp?
i also have a extra set of tweets on the pilar.
i understand wiring up the sub,i will just tap into the rear speakers.(behind the seat)
Old 10-03-2009, 09:18 PM   #8
Trader Rating: 7
Where's the Beef?
Here's another thread on the same subject in case someone worded it better than I did.
Adding amp to stock radio
__________________
-Joshua
Old 10-03-2009, 09:21 PM   #9
Trader Rating: 5
mred's Avatar
josh your doing fine.
i just wanna make sure i do understand.
i actually have the LOC's also,they are adjustable.
so i can use the locs for the front speakers and then tap into the rear speakers for the sub.
Old 10-03-2009, 09:34 PM   #10
Trader Rating: 7
Where's the Beef?
Yes. I had actually posted the other link at the same time you replied. You just beat me on the post.
I'd do the doors the same as your doing the Sub.
The only difference in wiring is where they go really. You can either get your front feed by tapping in behind the radio or behind each speaker. Whichever you think will be a cleaner install and allow you to hide the wires better.
Run the front and rear outputs into a 4 channel amp and then from the amp to the speakers.
Unless you are leaving the rear 4x6"s unhooked in which you would have a 2 channel amp but you get the idea.
Unless someone chimes in with a better way to do it that i'm not aware of.
__________________
-Joshua
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
amp, amplifying, converter, escalade, factory, jeep, line, outputs, radio, radios, rca, srt8, stereo, wire, wires, wiring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
