Relocating PCM
Relocating PCM
I'm currently in the process of cleaning up all the factory wiring and relocating my PCM out of the way. Is there any factory wiring that should not be extended? I didn't think so, but I wanna make sure especially for the coil packs, and injectors.
thanks.
thanks.
i relocated mine inside the cab. if you take the factory loom and tape off you can get quite a bit of slack. the only think I had to extend were the alternator and throttle body.
check out my build thread. I have a few pictures in there.
https://www.performancetrucks.net/fo...-build-506406/
Wrecker 426
09-30-2015 09:39 PM
kalikid06
09-20-2015 07:46 PM
muncie21
09-07-2015 09:55 PM
