Big shock to truck when Efans come on
I have a 02 Sierra, supposed to have a 180 amp alt but I never verified. When my Efans kick on it seems like there is a huge shock to the truck and it's like e everything dies for a quick second. What cause this and what can I do to fix it
Mine does the same thing, especially if I turn the ac on and they both kick on. A bigger alternater is the solution I would think cause after the initial shock it's about normal, but it feels like it sucks about 100hp out of the motor when they first come on for the ac. I've got like a 105 amp alternator I'm pretty sure. It's a stock replacement for 99 and it's too small.
I have a gauge for that
Its actually a factory 145amp one from an 07 or something. I dont believe there were any factory 1wire-4connector ones that will drop in. You have to replace the regulator, which isnt hard, but is about $45.
You can upgrade the stator while you are in there if you want to for more output. I think the details are in my build thread in my sig if you search that thread you should find it.
just get one that is from 04 or older and it will have the 4 pin connector that the older trucks used. in 05 they changed to the 2 pin where the pcm controls it.
