Best route for JL Audio subs using a JL Audio 500/1 amp for a '06 2500HD crew cab?
9 Second Club NA
This is becoming a headache for me. I can't figure out or decide what to do. I'm no expert at car audio systems and need everyone's opinion. I will be running a JL Audio 500/1 "slash" series amp. What size, series, and number of JL Audio subs can I fit that will compliment the amp I will be using? Should I go under or behind the seat. I've gotten so many different suggestions and have read just as many that I don't know what to do. I want loud clear bass. I really don't want to modify anything, but if a must, then keep it to a minimum. This is for my 2006 2500HD crew cab.
I'll also be running a JL Audio 300/4 with Focal 165V2 components and 130CV1 coaxles. For the head unit, I'll be using an Alpine IVA-W200.
Any help is greatly appreciated. Thanks.
"All Motor 9 Second club member"
I'll be glad when you get it all installed. I'm picking up my new 1500 Crew Cab tomorrow and I'll be installing a sound system as well. I'll let you be my ginny pig
Good luck!
Good luck!
what a rush!
9 Second Club NA
I'm not looking for so much the easiest, I'm looking for something that will sound awesome and won't require too much to get it to fit. I don't want to go any lower than a W3 series JL Audio sub. So whether its an 8 or 10 and the number of subs, they must be at least W3s.
On the other hand, I've been recommended by a buddy of mine who's been doing car audio/video/securty for about 15 years now states that for the best sound using 10W3s would be to go behind the seat with a custom enclosure, but having to move the seat forward 1".
what a rush!
FWIW, I had a 1500HD that I did the exact same thing too, infact, Blownchevy may still have some photos of the box
9 Second Club NA
moregrip, so you're saying without moving my seat, there's about 4.5" to 5.5" mounting depth? What do you mean by countersinking and adding another 3/4"?
Honestly, I really don't want to move the seat forward, but I will if I absolutely have to. But...if it had to be moved, I'd rather go up than forward. The way I see it, if you can make 2 10W3V2s fit behind the seat with moving the seat forward, then there shouldn't be any reason why it wouldn't fit under the seat with moving it up if need be.
what a rush!
here's some pics of my old box, currently BlownChevy's box. These 10" subs are countersunk, in other words, not just top mounted, there is another sheet of 3/4" MDF around the outside of the subs
9 Second Club NA
I'll check out my truck later this evening when I get off of work to see if I'm able to move it forward any. If anything, I can slot/enlongate them a bit and move it forward. I really didn't want to move it any more forward and give up leg room for rear passengers. Anyhow, I'm set on JL Audio subs. I would like to run at least a W3 series, so any other subs are out of the question.
So you're saying between the box and sub, there's a layer of 3/4" MDF so it pushes the speaker out an additional 3/4" away from the box? If that is correct, wouldn't adding a 3/4" spacer/ring around the hole between the box and speaker be doing the same thing? If so, does that give the speaker any more air space?
what a rush!
