All speakers work when hot inside, only tweeters work when cold?????
If you've got the radio removed, put a AA battery to the + and - terminals of one of the speaker wires at the deck. If it's cold and you hear them 'pop' a little due to the voltage, then your wiring is fine and I have no idea what's wrong. This will at least eliminate anything on the deck/head unit end of the troubleshooting. I wasn't aware the LS trucks has separate tweeters usually. Is the tweeter that you're hearing part of a 2-way speaker all mounted in the door, or is it in a different location?
2004 Silverado LS Front Speaker problem
I to have a problem sorta like this. My front speakers are intermittent. I start up truck and speakers do not work, but, after driving for awhile they come on startling me. The scenario is the same. When cold no worky, when warm(hot) they work. I pulled radio no connection problem. Pulled door panel. One thing I noticed was, it started happening after I had a very slight front connection with another vehicle. Was under 3 mph.
It sounds like one of the wires is bad,probably in the doors themselves. Start by checking your connections at the speakers, look for corrosion, evidence of excessive moisture, etc. then check where they move into the cab, everywhere there is a grommet, finally, check the connections at the radio. Check the pins in the connectors too (if using a factory harness).
My guess is that a pin is loose in one of the connectors in the doors. Honestly it's just a shot in the dark, but that's where I would start and it only takes 5mins.
hmmm my 05 crew cab has the same issue. only front driver side speaker works completely. passenger side is very faint and rears not at all this just started now that its getting cold out
stereos working only when hot
hi guys,
did you have any real culprit on why these gm trucks and cars "stereos work only when hot" issue? i just had the same recent problem with my 06 envoy. same issue. only tweeters during a not so hot inside temp.
please advice
please advice
