Aftermarket seat heaters
Old 09-06-2015, 06:05 PM
Resident Retard
BlackGMC's Avatar
Default Aftermarket seat heaters
I will be adding a set of Katzkin leathers and i wanted to add some seat heaters too. I was wondering which ones people add. I found a universal seat heater set made my Dorman i was thinking about buying. Any other suggestions?
Old 09-06-2015, 09:08 PM
I have a gauge for that
Atomic's Avatar
Youre in Texas...you should be looking into aftermarket seat coolers, not heaters
Old 09-06-2015, 09:13 PM
Resident Retard
BlackGMC's Avatar
It gets cold here, well kinda cold. What can i say i am a wimp that likes his butt warm
Old 09-06-2015, 09:56 PM
Hunt&Fisherator
silver-mod-o's Avatar
Just another use for some AN fittings.... Run some nylon tubing from your radiator, under the floor, into the seats and back out. Use a needle valve to regulate the flow. Barely cracked would give you a nice rump roast... Wide open would burn the buns
Don't forget to top off your coolant
Old 09-06-2015, 10:11 PM
Atomic's Avatar
Thats actually not a terrible idea haha
Old 09-06-2015, 10:25 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
My duramax has aftermarket seat heaters under the factory leather. They weren't working when I bought the truck. I looked at the fuses once, never went any deeper. They still don't work, and I still don't know why. LOL
I have no idea what brand they are.
Ain't I a lot of help?!?
Old 09-06-2015, 10:54 PM
Wolftrk99's Avatar
I swapped a harness from an 02 2500 lt into mine with set of avalanche seats, ever thought of adding factory heaters and just putting power and ground to harness?? I know most of the 99-02 ls trucks were prewired but im sure the 04 had something to do with ddm or bcm so may not be easiest, may be something to look at though...
Old 09-07-2015, 12:28 PM
Resident Retard
BlackGMC's Avatar
I think mine would be controled by the BCM. I really dont want to deal with getting it reprogramed.
Old 09-07-2015, 01:36 PM
musclecity85's Avatar
katskinz makes there own brand of seat heaters. i believe there called cabotex or karbotex heaters..they work great, and heat up fast. i use them frequently.
Old 09-07-2015, 03:05 PM
Wolftrk99's Avatar
Fair enough, had seen somewhere where guy used pre02 harness and switches and just wired it to power and ground... So he still had somehwat factory look without having to reprogram anything, been while since i was looking for info though!!
Quick Reply: Aftermarket seat heaters
